2013 MDX cricket noise
Old 12-15-2019, 07:05 PM
3rd Gear
nonezone's Avatar
After driving on highway for almost 20 minutes, there is a small noise like cricket singing, but I can not tell where it comes from. Any idea for this? And it is a 2013 MDX, base model.
Old 12-16-2019, 08:39 AM
AcuraAddicted's Avatar
It would be really hard if not impossible to diagnose this remotely using description of the sound.
Can you record the sound?
Does this sound appear only when driving, or when parked with the engine running as well?
Does the pitch change with RPM?
Old 12-16-2019, 02:03 PM
Received 8,584 Likes on 6,630 Posts
hub or axle would be my guess
Old 01-12-2020, 12:44 AM
elrifas's Avatar
Had a similar problem, mine was a loose bolt on a bracket close to the alternator.
Old 02-14-2020, 10:14 PM
3rd Gear
nonezone's Avatar
Had to go to the dealer, and replaced the propeller shaft.
Old 02-15-2020, 10:59 AM
ElectroMechanicalEngineer
djtsmith007's Avatar
How much did they charge? There are quite a few forums discussing this noise coming from the bearing mid way on the propeller shaft. Last i looked its still about $700 for the shaft since you cannot get the bearing replaced alone.
Old 02-15-2020, 10:28 PM
3rd Gear
nonezone's Avatar
Pretty costly, around $1500, including diagnosis. Have to say, the reliability of Honda is going down. May try another brand for my next car.
Old 02-16-2020, 10:31 PM
Wow. The propeller shaft only costs $700. What's the rest $800 for? It takes about half an hour to swap the propeller shaft, just a matter of unbolting the old one along with the protector and bolting the new one in.
mjwill99
3G MDX (2014-2020)
02-14-2022 06:51 PM
Sparky1951
3G MDX (2014-2020)
22
12-05-2020 10:34 PM
SipsAcura
3G MDX (2014-2020)
02-27-2019 07:43 AM
Waldo73
3G MDX (2014-2020)
06-21-2018 10:38 AM
Brad Mower
3G MDX (2014-2020)
14
09-15-2015 07:54 AM
Quick Reply: 2013 MDX cricket noise
