Tundra 86'd for an 86 which was 86'd for a Sequoia
Old 03-28-2024, 09:30 AM
  #3761
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,159 Likes on 4,818 Posts
As much as the belts will hold
Old 03-28-2024, 09:34 AM
  #3762
GO RANGERS!!!!!!!!!!!!!!!
e30cabrio's Avatar
Received 1,782 Likes on 1,240 Posts
You gots no oil pressure
What's your expected peak boost once it's all sorted?
The VDO senders are not working. Gaaaaaaaa
8 is max quoted for a used S/M52. I have ARP studs and a beefier head gasket. The builder says stay under 10.
I'm 4 sizes down, each reduction is 1/8".
I think one or 2 smaller might be where it lands
Old 03-28-2024, 09:47 AM
  #3763
Received 5,303 Likes on 3,637 Posts
Is the current, smaller belt slipping under WOT?
What do you estimate the WHP is at 5lbs?
Old 03-28-2024, 10:00 AM
  #3764
e30cabrio's Avatar
It does not seem to be slipping, It "feels" loose. I need to be able to drive it without fear of losing the belt is why I say I may land smaller.
No clue what the HP is. It feels pretty damn good. Eventually I will get a dyno. First, need an alignment, and to button up the interior among other things.
civicdrivr (03-28-2024)
Old 03-28-2024, 10:59 AM
  #3765
civicdrivr's Avatar
Ozempic?
ttribe (03-28-2024)
Old 03-28-2024, 11:08 AM
  #3766
e30cabrio's Avatar
Ozempic?
Thanks, now that damn song is in my head.
Just ordered the next 2 down, the bigger of the last 2 untouched going back, the smaller will go back when I get the smaller one on.
Old 03-28-2024, 11:45 AM
  #3767
civicdrivr's Avatar
Old 03-28-2024, 04:36 PM
  #3768
e30cabrio's Avatar
The following 2 users liked this post by e30cabrio:
civicdrivr (03-31-2024), godfather2 (03-29-2024)
Old 03-30-2024, 01:07 PM
  #3769
e30cabrio's Avatar
The bung is in!
The following 4 users liked this post by e30cabrio:
CCColtsicehockey (04-02-2024), civicdrivr (03-31-2024), godfather2 (03-31-2024), ttribe (03-30-2024)
Old 04-02-2024, 11:20 AM
  #3770
e30cabrio's Avatar
Last Saturday I went to replace my spark plugs, the first plug I pulled front of the engine, driver side had a huge amount of oil in it.
Auto Nation Tempe, did the Cam Tower repair 4/6/23. I called to make an appointment to get it fixed under their 12 month, 12k warranty, (it is under 7k miles) they hemmed & hawed about paying for a loaner. I said the spark plug tubes were not leaking when I gave it to them ergo they messed it up.
I am awaiting a call back from the service manager.
Old 04-02-2024, 11:47 AM
  #3771
e30cabrio's Avatar
The manager called, said I have to get it in by Saturday, there is no "grandfathering" from making the appointment last month. I said I have an appointment Saturday, now I have to change my alignment appointment Saturday at 9am to bring this in at 7am.
Wheee!
Old 04-02-2024, 02:26 PM
  #3772
e30cabrio's Avatar
The sensor for the AFR/boost gauge is defective. Reads 22.4 when revved and 7.4 at idle.
Searched forums, found it's a known issue if the gauge does not like the ground.
Opened the pita to open center console ran the ground to a bolt holding the gas pedal assy on the car, no change. As I bought the PSB1 direct, called Innovate. After some drama, they are sending another O2 sensor.
I have one I bought for the Sequoia that disappeared, searched and searched, then it occurred to me I put the new one in the box the gauge came in.
Mystery solved!
Old 04-02-2024, 09:28 PM
  #3773
e30cabrio's Avatar
Got the PSB1 "working" but it's readings make no sense. 10.x at idle up to 15 at throttle. WTF?
Old 04-03-2024, 09:46 AM
  #3774
rockstar143's Avatar
Received 19,917 Likes on 14,459 Posts
"git yerself a new map"
Old 04-03-2024, 03:20 PM
  #3775
e30cabrio's Avatar
What?
Old 04-04-2024, 06:48 AM
  #3776
Tommy boy reference but also a tuner reference.
You are a machine, man. Wow.
e30cabrio (04-04-2024)
Old 04-05-2024, 09:34 PM
  #3777
e30cabrio's Avatar
The M master cylinder & master vac came with a check valve, I put the valve in, brakes are back. New valve is coming tomorrow.
Old 04-06-2024, 01:55 PM
  #3778
e30cabrio's Avatar
Took the Tree to Toyota, I get they have to verify themselves but (A) who makes up a spark plug tube full of oil & (B) who opens a valve cover to damage the gasket?
They determined it needs to be replaced & gave me a '24 Highlander loaner. (last year it was a '23 Tacoma)
On the way home I called Firestone. They got me in, I dropped the Z off on the way to the airport to drop my Daughter and it was ready when I got home.
It feels amazing!
The following 3 users liked this post by e30cabrio:
BreezyTL (04-08-2024), civicdrivr (04-06-2024), rockstar143 (04-08-2024)
Old 04-08-2024, 03:39 PM
  #3779
e30cabrio's Avatar
I got 20mm spacers for the rear & moved the 15mm to the front.
CCColtsicehockey (04-09-2024), civicdrivr (04-08-2024), ttribe (04-08-2024)
Old 04-08-2024, 04:01 PM
  #3780
Received 5,858 Likes on 3,871 Posts
Clean those wheels, damn!
BreezyTL (04-09-2024)
Old 04-08-2024, 04:12 PM
  #3781
e30cabrio's Avatar
I have had bigger fish to fry & washed both the Prius & Tree. This has the garage so it will be washed last. (most likely Saturday)
Old 04-09-2024, 09:15 AM
  #3782
e30cabrio's Avatar
Decided 5mm more in back might be best, ordered a 25MM
civicdrivr (04-09-2024)
Old 04-09-2024, 11:48 AM
  #3783
e30cabrio's Avatar
Autonation Tempe are thieves, they say the Valve cover gasket on the passenger side is bad as is the front passenger LCA, they did the driver LCA last year, I did not think it made sense not doing both then (they did not do them last year) Makes no sense in under 6k miles they magically went bad. They want 2k to do both, I ordered the gaskets for 40 & am looking for the LCA.
Old 04-09-2024, 01:54 PM
  #3784
e30cabrio's Avatar
Ordered the control arm from Serra Toyota. 290.08 shipped, no tax, free shipping.
Watched this video:
How is that 1200+ in labor???
Hardest part is taking off the tire, even on that totally rusted suspension
Old 04-09-2024, 02:52 PM
  #3785
CCColtsicehockey's Avatar
Received 3,668 Likes on 2,499 Posts
The don't call them stealerships for nothing
The following 2 users liked this post by CCColtsicehockey:
civicdrivr (04-09-2024), e30cabrio (04-09-2024)
Old 04-09-2024, 08:07 PM
  #3786
civicdrivr's Avatar
Wait, why isn't your warranty covering it?
Old 04-09-2024, 08:29 PM
  #3787
e30cabrio's Avatar
It expired last year after they fixed the cam tower leak & driver side upper control arm.
Old 04-09-2024, 08:49 PM
  #3788
civicdrivr's Avatar
Boooo
Old 04-09-2024, 09:10 PM
  #3789
e30cabrio's Avatar
I'm good doing it myself.
Old 04-11-2024, 10:38 AM
  #3790
e30cabrio's Avatar
Felt a bit more in back was warranted, got 25mm, it's perfect!
Sitting a bit high as it has not been moved since jacking it up.
civicdrivr (04-11-2024), ttribe (04-11-2024)
Old 04-11-2024, 09:53 PM
  #3791
e30cabrio's Avatar
civicdrivr (04-12-2024)
Old 04-12-2024, 10:10 PM
  #3792
e30cabrio's Avatar
godfather2 (04-13-2024)
Old 04-13-2024, 11:49 AM
  #3793
e30cabrio's Avatar
First oil change, magnetic drain plug did a good job, surprisingly clean considering it's a new motor.
I know it is a waste but sending a sample to Blackstone.
Motor is "done" all is well & it is amazing!
CCColtsicehockey (04-24-2024), civicdrivr (04-14-2024), godfather2 (04-14-2024), ttribe (04-15-2024)
Old 04-13-2024, 03:46 PM
  #3794
e30cabrio's Avatar
First real wash in months.
The following 6 users liked this post by e30cabrio:
CCColtsicehockey (04-24-2024), civicdrivr (04-14-2024), godfather2 (04-14-2024), rockstar143 (04-15-2024), SamDoe1 (04-15-2024), ttribe (04-15-2024) and 1 others liked this post. (Show less...)
Old 04-15-2024, 11:34 AM
  #3795
BreezyTL's Avatar
Im sure it is just the machining left overs. But at least it will give you peace of mind about it. Looks great!
e30cabrio (04-15-2024)
Old 04-19-2024, 09:09 PM
  #3796
e30cabrio's Avatar
Logs show weird MAF fluctuation so I replaced the intake hoses with smoother/less twists.
CCColtsicehockey (04-24-2024), civicdrivr (04-20-2024), godfather2 (04-20-2024), ttribe (04-22-2024)
Old 04-26-2024, 07:12 AM
  #3797
e30cabrio's Avatar
Meanwhile, back at the Tree, I replaced the Flex ECU with a non flex, I had already deactivated/removed/bypassed all the mechanical flex systems.
The truck is running much better!
Old 04-26-2024, 02:42 PM
  #3798
e30cabrio's Avatar
Just drove 40 minutes each way to drop the M vent panels at the body shop, he said he needs the car to paint them, I said I thought you could figure the color, that's why I came in the car. He looked me dead in the eye, said do you know what color this is? I said Atlanta Blau metallic #306? He said NO! It is NIGHTMARE BLUE. I need the car.
lol
I left them so he can start the preparation & will drop it off in a week or 2 when it is absolutely too hot to drive.
ttribe (04-26-2024)
Old 04-27-2024, 11:00 AM
  #3799
I would have left him the gas door.
Figure it out, chief.
Old 04-27-2024, 01:02 PM
  #3800
e30cabrio's Avatar
I'm ok making sure it matches.
Brakes were new when I bought the Tree, (unbeknownst to me) I bought new brakes before I got it. I have had worsening shudder on the freeway so figured the rotors were warped & just installed them.
New pad on the right, I put 25k miles on them, kinda shocking how much is left.
Quick Reply: Tundra 86'd for an 86 which was 86'd for a Sequoia
